Automatic or Manual Car Transmission?
Tofiq
        Automatic or Manual?
If you have planned to obtain a vehicle and therefore are overcome whether you should purchase manual or automatic cars, this write-up provides you with useful tips which supports you get to a variety.
Knowing the idea
Now let us first know very well what the word automatic or manual vehicle means. Automated cars mean automatic transmission cars, which will change gears instantly, without your aid and in addition don’t require another pedal or even the clutch to change gears. However, manual cars make reference to stick shift cars which need learn using a clutch to change gears. In stick shift automobiles, you’ll require to take advantage of both ft they are driving the vehicle.
You will find pros in addition to cons of both automatic as well as stick shift cars. At this time we shall study the main difference between your automatic and furthermore manual cars on various parameters that will help you get to a choice.
Cost factor
Automobiles with automatic transmission tend to be more costly than automobiles with stick shift. Therefore if you’re rate sensitive in addition to want the thought of saving a couple of $ 100, then you definitely should certainly choose the less pricey manual tranny cars.
Maintenance factor
Maintenance cost of automatic tranny motor is in addition to that of stick shift cost. It is because fixing of automatic transmission system requires much more skill as well as time. Furthermore, manual tranny automobiles can run for hundreds of miles without needing any maintenance.
Both manual and thus automated transmission automobiles require change of lubrication regularly. The requirement of lubricant change is a lot more for automatic cars although most carmakers utilize special liquids in automatic transmission vehicle to ensure that you might not need change of lubricant whatsoever.
Convenience of operation
Individuals that are new motorists as well as aren’t cozy while using third pedal may find the idea of automatic transmission far more comfortable. Additionally you will have to concentrate more about driving when utilizing a manual vehicle, which can be tough when you’ll need you need to drive with crying babies or when driving in high traffic. Although, those who are accustomed to stick shift can be okay by using it. Also, in a number of situations, stick shift makes driving much more cozy.
For example taxi motorists, who require they are driving fast or when you really need to visit up-hill stick shift makes driving simpler because it allows you to definitely accelerate or possibly p-accelerate a vehicle faster while automatic transmission requires a during accelerating or possibly slowing down hence you may want to take advantage of brakes to slow it lower. Although, if you’re not comfortable switching gears by hand, may still choose the concept of automatic transmission.
Hence you will find both negative and positive points of both automatic in addition to stick shift autos. You will find know privileges and wrongs as professional motorists can drive on kinds of vehicle easily. However, if you’re a seasoned driver and would enjoy cost saving, stick shift could be good selection for you.
На Русском языке
Давайте разберемся в достоинствах и недостатках механической и автоматической коробки передач. Очень трудно побороть менталитет, когда многие аспекты рассматриваются с точки зрения устаревших позиций. Есть мнение, что автоматическая коробка передач больше подходит для женщин. Конечно, с этим трудно не согласиться. Однако не стоит упускать из виду то, что современная автоматическая коробка передач — это очень сложный механизм, со встроенной системой контроля за стилем езды водителя (коробка как бы следит за ездой водителя и подстраивается под него). Существует режим антибуксировки, режим эмуляции переключения и многие другие полезные функции. Автоматическая коробка передач очень хорошо себя показывает при езде по городу, где переключение передач нужно практически каждую минуту.
Главный минус автоматической коробки передач — это ее большая цена покупки, эксплуатации и ремонта. Если у вас сломалась автоматическая коробка, то большинство обращаться в автосервис, где ремонт будет дорого стоить, да и автомобиль с автоматической коробкой стоит намного дороже автомобиля с обычной механикой.
Говоря о преимуществах механической коробки передач, то стоит выделить ее надежность и износостойкость, а также маленькую стоимость покупки и ремонта. Водитель, имеющий опыт в ремонте коробок передач, сам всегда отрегулирует ее, не обращаясь за помощью в автосервис. Еще один немаловажный положительный аспект — это более низкий, по сравнению с автоматической коробкой, расход топлива.
Главный недостаток механической коробки передач — это ручной способ переключения скоростей. Он требует от водителя постоянного напряжения и определенной сноровки, особенно в городских условиях, где скорости нужно переключать очень часто. Из-за каждого переключения передач теряется скорость автомобиля.
Вот основные достоинства и недостатки механической и автоматической коробки передач. Сравнивать их очень сложно, все равно, что сравнить калькулятор со счетами. Каждый водитель в своем выборе опирается на свои предпочтения и опыт вождения. Удачи вам!
Изменено пользователем Tofiq
Изменено пользователем Яся
Я за Мкп т.к она надежней ее трудно сломать и она намного вынослевее автомата!!!
А после наших водителей автомат еще и убитый и + на Мкп машины дешевле на 1-2т $)))
Внимание!
Стоп оффтоп
mexanika 4 ever
Max 35 yasha kimi.
niyeki 35dende cox surmek olar
Isi baxir surenin zovqune, surduyu muhite. Adam varki butun gunu tixaclardadir, ya da magistralda ve s. Ela insanlara menanika yaramir. Ela insanlarda var ki, sirf mexanika terefdaridir, onlar ister tixaclarda, ister magistralda, ve s. surselerde, mexanika tercih edirler
BU temanin menasi nedediki?
Biz neyi muzakire eliyeki bu barede?
Manual Transmission.
Xususen key avtomatlardan aciqim gelir, ele pis yerde adami gecikdirir ki az galirsan avariya edesen...
Avtomati surmey uchun gerey geweng rashotun olsun.. Aborotu yigib chixmaq lazimdi. Yoxsa arxadan gelen sagini aparir)))
Theme: Mexanika
Mexaniki transmissiya.
