zLoY_AzERi[KZ] Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 Evosport CLK63 Tuned to 600 hp, the Evosport modified CLK63 is the most powerful version of the Black Series to date. Evosport has already completed installing its new line of products for the Black Series on several CLK63s, including this pristine white model, which will be showcased in the Brembo booth at the 2008 SEMA Show. The performance package includes Evo Full Race long-tune headers, an Evo three-inch full exhaust system, cat-delete, an Evo Power Pulley System, an Evo2 ECU tune, carbon airboxes and intake spacers. A similarly equipped car (but with a more modest engine tune and its cats intact) measured 480 hp and 443 ft-lbs of torque on a dyno – which equates to roughly 571 hp and 527 ft-lbs of torque. Evosport did more than just modify the engine though. The interior received Evo’s carbon trim kit while the exterior got a Vorsteiner carbon fiber front splitter and plenty of other custom details, like blacked out exhaust pipes, tined tail lights and a blacked out front grille. To improve handling, H&R Race Springs were installed and H&R wheel spacers give the car a slightly wider stance. When it arrives at SEMA, the car will be outfitted with stunning carbon/magnesium Dymag wheels, which weight just 17-lbs in the front and 17.5-lbs in the rear. As for the brakes, well, with the powerful factory Brembo six-piston calipers with 14-inch rotors up front and four-piston calipers with 13-inch rotors in the rear, there wasn’t much need to mess around with the big hardware, so Evosport simply upgraded the brake lines to stainless steel units and swapped out the pads Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Орханчег Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 вот это я понимаю тачка Содержимое этого сообщения скрыто.Чтобы увидеть его, вам следует войти на форум, или пройти регистрацию, если её у вас нет. Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
007 Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 непонятная дебилка в стиле хаманн Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
zubilo Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 007 Ты завидуеш мы знаем поэтому и ругаешь МБ пора бы уж свыкнутся с мыслью что большая часть человечества предпочитает МБ а уж асобенно в Азербаиджане. Сочувствую тебе. П.С Машина зверь слов нет,это МБ и этим все сказанно Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
007 Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 да мне как то все равно, пусть любят это мое мнение, и мне нужно чтоб все любили БМВ, любить это мало Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
KGB Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 он больной да, бенгл башыны фуррадыб ки эфирдя бэээмвени ПР еле сяня тязя М3 вераджам. лоол Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
orxan116 Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 Efir vidi var. Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Az-R Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 да мне как то все равно, пусть любят это мое мнение, и мне нужно чтоб все любили БМВ, любить это мало Pişiyin ağzı ətə çatmayanda, deyir ki sroku keçib Содержимое этого сообщения скрыто.Чтобы увидеть его, вам следует войти на форум, или пройти регистрацию, если её у вас нет. Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Farid_678 Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 Mercedes forever Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Орханчег Опубликовано: 23 декабря 2008 Жалоба Поделиться Опубликовано: 23 декабря 2008 М3 отдыхает рядом с ней Содержимое этого сообщения скрыто.Чтобы увидеть его, вам следует войти на форум, или пройти регистрацию, если её у вас нет. Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
007 Опубликовано: 24 декабря 2008 Жалоба Поделиться Опубликовано: 24 декабря 2008 RS 4 порвет его на куски, а М3 Hamann в падло стоять с таким чевяком Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
Az-R Опубликовано: 24 декабря 2008 Жалоба Поделиться Опубликовано: 24 декабря 2008 Чевяк няди? Ты уже от зависти съедаешь буквы....я уже не говорю о губах.... Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
MagerramoFF Опубликовано: 24 декабря 2008 Жалоба Поделиться Опубликовано: 24 декабря 2008 Красивая.. МБ рулит ) Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
